I've had my Con OFE in since January. After it was put in, I noticed that it was a little bit more grabby than stock, but I expected that since it held so much better. Lately it seems that it's starting to get worse, but only occasionally. Sometimes I can back out of parking spot as smooth as ever, but then there are times it will try to shake you apart. Same with taking off, sometimes smooth... sometimes shaky. This is the only vehicle I drive, so it's not like I'm jumping into it not used to the clutch.
I've also noticed that sometimes it's a little hard to get out of gear after easing back out of a parking spot or backing up to a trailer. Feels like there's still a little bit of pressure against the gears.
Could this be the master/slave going out? Or should I be looking somewhere else?
