Does anybody else with the six speed have a hard time getting the truck into gear occasionaly? At stop lights I usually keep the truck in neutral with the clutch pedal out. So, sometimes under this condition when I step on the clutch to put it in 2nd it won't go in unless I let the pedal out again, rev the motor a bit, and then it will slip into gear. BTW my transmission dosn't grind when this happens. My guess is that keeping the trans in neutral for a length of time, the gears stop spinning so the syncros can't do their job. Am I right? Does anyone else have a similar problem?
