Originally posted by jtisdale
I would suggest to take it to the dealer so they have a record of your problem
Originally posted by DHenry
I'm still refining my shifting technique for this particular transmission, but one thing I've noticed is that if I don't let all the way off the throttle so that RPM stay up a bit during the shift, it's much smoother. Or am I imagining it? Don't think so. Has anybody else experienced this?
Originally posted by Texas Diesel
HEYBOSS,
Sure wish we could find a synthetic that was approved for use in the 5600 series.
Originally posted by JTroiano
Try not using the clutch at all. When up shifting, let off the go pedal and at the same time put tension on shifter to go into neutral and it will pop right out, then put slight pressure againts next gear syncro's and when the rpm's are correct it will pop right in. I wouldn't do this all the time but it will dive you a good idea on what the trans. wants to see in regards to rpm's to shift, so when using the clutch wait a seconds to go into the next gear. Semi's don't use the clutch except to start from a start. If you want to down shift it is alot harder. You need to get it into "N" and then stab the gas pedal to get the rpm's higher than what it would be after down shifting with the clutch. Then put slight pressure on the lower gear and when the rpm's are correct it will pop right in. Don't try this unless you understand!!It takes alot of practice. I don't drive my truck like this because I heard that it is tuff on the sycro's. I don't know if this is true. But some times when it is hard to down shift I do let the clutch out and stab the throttle to get the gears to speed up and then it will shift right in. The only time I shift without the clutch is when I have a cup of coffee and am talking on the cell phone and steering with my knee.
Then I let the kid sitting in the middle shift, just tell them the number
Jon
Originally posted by HEYBOSS
I did a little research on red line gear oil and I don't think it is approved for the 5600, according to owner's manual DC already uses synthetic on the 5sp so for the 6sp they may be already using something similar or better. I'll still search it a little further and if something comes up I'll post it.
