Engine/Transmission (1998.5 - 2002) 6 speed problem
Engine/Transmission (1994 - 1998) Lean fuel mixture?
Engine/Transmission (1994 - 1998) Egt's at full throttle
Heres a question for you. i have posed a couple times on this topic. I have a 6 speed and about 25% of the time it will not go into gear from a standstill. this mainly happens when you are at a stop light and you go to put it into gear and it just wont go. Is not that it is grinding, it just wont go. also sometime when you stop it is hard to get out of gear. this does not happen as often but it does happen. Also when you are letting out on the clutch It has gotten really grabby not a smooth engagement. this is mainly from a second gear start. Hope fully i will be pulling the trans out next weekend to see what is going on. have any of you had these symptoms.
Trey
6 speed
When was the last time you changed the transmission fluid?The other thing is make sure you get the peddle to the floor to engage.
Its been about 30k since i have changed the oil. Its time to do it and the Redline mtl is on its way. I have been running the Amsoil.
