6 speed transmission
sanity check: new turbo… oil in intercooler
black smoke with throttle from stop
Could someone tell me the oil capacity for a 2005 6 speed? Gotta change it and I can't remember how much..... Thanks in advance !
Folks might want to know if NV5600 cast iron or later G56 all aluminum. 2005 had both of these.
Not sure if they are same or different capacity.
Thanks guys. It is the NV5600. Reverse is to the right and forward. I have always used the Pennzoil synchromesh transmission oil. I guess it takes 5 quarts + a bit extra.
This is what pops up. Not sure at times it's usually pretty accurate.
I have the coolers om mime (NV5600) and I over fill it, All together i put 8 qts in mine. Rumor has it the front bearing gets a little shy of oil when climbing inclines
