6 Way Turn Signal Conversion
What is the largest tire on a 2500 4X4
wheels from Port. OR to Everett WA.
Hey I clicked on your link and copied the URL addy then pasted it in and it got it so I can see the schem. Not sure why you link did not work. Here is the URL I used:
http://www.geocities.com/cummins_man/6WayTurnSignals.jpg
By the way after I did this the scheme showed on your post. Don't ask me why I don't know computers.
I hope this helps some of you!! #ad
2001 RAM 3500 dually Quad Cab SLT, 4. 10 limited slip, HO 245 hp, 6-speed, dark garnet pearl coat, interior agate, All options except heated leather, added DeeZee brite diamond tool box, Linex spray-in bed liner, Lund hood deflector 3 piece smoke color, DeeZee brite diamond cab/bed running boards and TurboSaver (from Gino's) also Reese 5th wheel 15k hitch. No plans to bomb. This is my retirment vehicle currently pulling 21' 5er want to buy 30 to 35 for retirment.
[This message has been edited by Bob Cochran (edited 04-06-2001). ]
Bringing this topic to the top again. As much as I like the looks of the dually box, it is off and a deck is going on. I want to put lights like Evan describes on my deck. When I try the link in Bobs post I just get the Yahoo make a web page (and that ain't no YAHOO)!!! Thanks.
2001. 5 3500 ETH-DEE 3. 53 gears
Patriot Blue SLT Camper and Towing package
Evan, want to say thanks for the diagram. Now i have another question. The multi function switch is mentioned. Where is it located and what will it look like? would like to get started but don't really have a direction to go yet. i've got the service manual, but i want to make sure that i'm looking at the same thing. thanks for the help guys!!!!
Daniel McKeehan
1999 2500 QC/Short Bed/4X4 5 speed. Camper Package and of course a Cummins.
The Multi-Function Switch is located in the steering column. Remove the plastic covers, and it will be under there on the left side. Your wiper, turn signal, and high beam circuits are all controlled through this switch. If you have any more questions, just post them here or shoot me an email. #ad
BTW, I just replaced my series 15 side turn signals with LED units. Major improvement, as the lights now have 8 LED's each, as oppsed to a single incandescent bulb before. #ad
Thanks Evan, that is the one i was thinking of. are the wires pretty easy to get to in the column? Has anyone found a good quality blade type fuse panel with more than 4 fuses other than a painless wiring kit? Looking for something with just the fuse block and i'll supply my own wiring.
Daniel McKeehan
Daniel,
Kragen has a fuse block for six blade fuses.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
I was doing some spring cleaning on my website and found this picture. Is this the same wiring that Evan does? Might have come from reading his message a very long time ago. tell me if it is not and I will delete this message
Rather than confuse things, I've deleted this image since the author's original is below.
Evan, do I assume that your diagram is good for 99 also??
99' SB 4x4 : DDI's, HOT PE, SACHS Clutch(here 2/19 but still in the box),SPA dual gauge, ESPAR, Line-X OTR, Ladder bars, AMSOIL, etc (GPS,Cell,CB,... . )
Green Monster
[This message has been edited by David_VT (edited 04-29-2001). ]
here is the diagram that Evan sent me.
Daniel McKeehan
no problem Evan. Thought it might help out.
Daniel McKeehan
Hey Rob. . . no not yet, haven't gotten around to it :( I am going to look in the steering column and see how it is hooked up, but will probably check with the expert too. I think when I get around to getting it hooked up I'm going to add the switch so I can manually override it, for those dark nights when I'm loading up or undloading. Thanks for the help the other day though :) I'll let you know if I get 'er figured out.
Vaughn
