Thanks Cumminz Thats much better. Sounds like it should be a winner.
Now how do you rate it against the new 6 speed allison.
I have not only driven but towed with all three now. I have always said the 06 D/A Z I have driven is a very refined and powerful truck. My main concerns with it were fuel mileage which is about 10-15% lower than the 06 CTD for basically the same power, constant down shifting on normal hills, the gearing for towing at 70-75mph, and the throttle lag.
I had the pleasure to tow with my friend's 68rfe out of the Smokey's yesterday. I drove 200 miles to Balsam, NC so I could ride out of the mountains with him towing his 14K fiver.
He wanted me to drve it out myself but I was frankly nervous about driving it loaded in the mountains. I had only driven it a few mile when it was new and unloaded.
He took us through the first forty or so miles and then pulled over on a steep incline and told me to drive. I must say that it was the most relaxed towing experience I have ever had. I had a ball as I basically "watched" the truck shift and apply the E brake. Then I "played" with the manual shift button which I found I could use to smoothly down shift too for braking to a stop. Previously unloaded I had down shifted without using the throttle and nearly lost my teeth as the E brake "caught".
I thought he had driven through the worst sections of road until I hit curves on the two lane section up and down 6-8% slopes. The truck is incredibly smooth applying E braking and power. Instead of "riding" the brakes through curves I found myself getting back on the throttle because the E brake had slowed the rig incredibly well. It will hold speed at 45-50mph down 7% slopes in 3rd gear at around 3K rpm and only the 8% slope pushed the truck from 46-52mph!
You have none of the throttle lag of the 06Z or the screaming red line operation I found towing with the Z pulling at most 8K with its version of engine braking.
When we got out of the mountains I was totally relaxed and ready to make a U turn and hit some more mountain curves!
The only criticism I have of the transmission is one that I have found in the 06 48re. Even in T/H mode it occasionally would not down shift and allow the engine to lug at 1100 rpm. It only did this twice to me making rolling turns at very low speeds. The manual shift easily solves the problem, but really how hard is it to program the computer to shift down at 1500rpm under light throttle in T/H mode? I have never experienced that with the D/A honestly.
He hasn't computed his mileage out of the mountains yet, but he got 8. 4 going to Moon Shine Creek. I don't think that is bad considering the truck had 1500 miles on it and the route he was taking. Time will tell if the mileage improves, the emissions problem is solved, and the 68rfe is as reliable as the 48re.
All I can say is it is one hell of a towing machine, very comfortable, and hands down much stronger than either 06 I have towed with. If it "loosens" up like the other CTD's have it will be scary to think how strong it will be at 20K.
One safety concern we have. Since we used the brakes only a few times at stops and on 8% curves we think Dodge should provide bumper stickers and possibly a brake light switch to operate when the E brake is functioning to let Ford and Chevy drivers know the rig may slow without warning!
I hope my friend gets caught up on his golf and "honey do list" after his two week vacation so he can give you his impression of the truck compared to his 2003 HO 48re.
By the way, we both still agree you don't need 4. 10s pulling at max GCW with the CTD. Second through fourth gear are beautifully matched to its wide power band. Fifth is very strong and in sixth you can idle or fly!
You truly have to tow heavy with this truck to believe how great it is. Oo.
