My 2015 Ram 2500 with 68RFE transmission (44000 miles) threw a CEL. Pulled the codes and they are P0933 pressure sensor range performance, P0869 Trans fluid pressure high and a P0935 Hyd pressure circuit high output. ATF looks good. I checked the pressures sensor connection, and it is clean. Dropped the pan to inspect the filters. Saw no issues but installed new Mopar filters. Refilled with new ATF+4. Cleared the codes, but they come back in short order. My scanner will not read drive pressures, so tomorrow I'm taking it to my brother's shop as he has a really good scanner. I'm hoping it shows as a faulty sensor and it is not an over pressure issue as the code suggest. I do not want to continue to drive it until fixed for Fear of damage. Truck is completely stock. Any ideas/ suggestions would be appreciated.
