Having some trans problems with 07 mega 6. 7 4x4. I noticed the other day that it seemed like it didnt want to shift into the upper gears like normal. Then this morning my friend, who drives my truck when we snowplow b/c I am running one of our loaders, got it stuck in 4wd low. I got in it and got it back into 2wd after only a few minutes. On the way back to the shop I noticed that the shifting problem had gotten worse, not sure if it has anything to do with being left in 4 low, but could be a contributing factor. The shifting problem, from what I can tell, is from 4th to 5th gear. The rpms fluctuate and feels like the trans is slipping, then will shift into gear and seems to run ok. I have been doing some research on this transmission and have come to find out that there are filters inside of it and one of them is a spin on filter. I had no idea it was in there the filters that are on my older trucks are a simple screen on the suction side. Our maintenance for transmissions is every 20,000 miles to suck out the fluid and replace it with new. We run amsoil atf. I consider myself pretty competent and diligent with maintenance issues. But I am very upset with myself for not knowing about these filters. I have never changed them. I think the dealer may have around jan. 2009 when the truck had 25,000 miles. It now has 130,000 miles. The truck has the egr deleted, along with the dpf removed and replaced with a 4" straight pipe. I also have an H&S xrt programmer tuned to the performance setting. I aint gonna lie about the truck being babied either. This thing works. Hauls heavy trailers and moves mountains of snow. My friend is a trans rebuilder and is on his way to test drive the truck to give his opinion. I'm pretty sure I'm in store for a trans rebuild, but am hoping and praying it may just need filter changes. Was wondering if anyone has had this problem and turned out to just need filters and not a rebuild. I kinda doubt it. But you never know. Thanks for reading and hope to hear some good news. Also if it does need a rebuild was wondering if anyone could point me in the right direction for how much and what kind of parts to put in it so this doesn't happen again.
