68rfe shifting problems
Plug-and-Play Exhaust Pressure Gauge
Boost gauge install
All the old Mercedes Benz Diesels I have owned, 1979-1997 had a converter drain plug, it was nice for trans service, but the lower section of the bell housing was a removable sheetmetal piece, the Dodge does not have access, so it wouldn't help much
Trans is back in. Had a clunking noise in driveline somewhere, was freaking out about it, then crawled underneath and found that I forgot to tighten the driveshaft to the rear end. But now have another problem that has resurfaced. Started a thread about 2 months ago for the abs light, brake light, check gages light and the speedometer doesn't work.[/QUOTE
My truck is an 07 and if the spare fuse gets pulled I loose speedometer and everything else you listed hope this helps.
Shill, this thread is 3 years old
