Dana 44 with a Cummins
I have a 85 Dodge Ramcharger that I put a 160 HP Cummins diesel in in 1992. I have 114,000 miles on the clock since the conversion and so far the Dana 44 has held up well. I did put snow plow springs for a 1/2 ton Dodge pickup under the Cummins when I did the conversion. I'm not hard on the vehicle and don't do hard 4 wheelin like others on this web site but I use 4 wheel drive occasionally, (usually to pull my 2WD 89 Ram out of the front yard while moving the travel trailer). I just had to replace the non-disconnect side axle shaft seal at nearly 200K on the axle. The oil still looked new! I think that as long as you take care of the axle it will take care of you. I have the NP-208 transfer case which is what I believe is the weak link in my particular drive train on the 4WD side. So far no issues. I posted my problems with the axle seal replacement over on the Off-roading part of the TDR if you are interested. Ken Irwin
