6BT harmonic balancer for 4BT????
24V versus 12V versus 8V?
4BT in TDR issue?
On another site, a gentleman was stating that they always use 6BT Marine dampers/balancers on their 4bt's.
This allegedly makes a huge difference. Anyone have any experience with this.
I recall seeing two types of dampners for the 4bt, one is rubber for the 4bt and the other is silicone for the higher rated 4bta engine... .
I work on 4BTs in bread trucks all ours have no damper just a steel puley bolted to crank 4BT and 4BTA same puley and they viberate alot
whole lot of shaken going on-not !
Since i'm using a 5 speed getrag, I attached a 6bta flywheel and to my surprise , a smooth idle and mid range, even when attached to jack stands... i'll follow up with a report after it is installed... ...
