Hello everybody, I got home last night bout 1:30a. m. and went to sleep only to get up in the morning to see a oil slick under my truck. several good size pools. motor oil I believe. front of engine dry, but back under trans is soaked. Rear main? Are these prone for failure? oddometer tickling the 150,000 mark. big job to take the trans/transfer out? I mean bigger than a gas 4X4? I have done few of those. Going to do a major refresh on the truck. what are your suggestions for part replacement. going to tab my kdp. so front will be apart as well. Another question, does the cummins need to be supported when taking the trans out? I am assuming it will. any of the fuel lines need to be disconnected for this procedure? What items on front of truck need should be replaced? Is the timing something I could check and advance myself. If I need to take gear case off, I have read that the cam gear can be removed by heating it. is this a good method? might even upgrade the valve springs. What springs do I look for. Intake/exhausst?
Any further help or advice will be greatly appreciated.
Am I biting off moer that I can chew here? Most of the work I will probably have to do alone as I work a stupid shift.
