Ozymandias
Buy a digital angle meter, from Amazon they are in the 20$ range and accurate.
Something like this >> Amazon product ASIN B00T6YZ0K6
I't been a while, but I believe they were all able to go 180°.You posted as I was typing my previous response. I will get a dial indicator and check runout. If I'm not mistaken thiugh you can not "phase" the front driveshaft. It makes up to the companion flange in only one orientation I'm pretty sure. Will definitely check and advise as I have time.
I get the same vibration at about the same speed but mine kinda pulsates. I very rarely go on the highway so I haven’t personally looked at it yet. Interested in seeing what you ultimately find
If caster is causing it you have a problem in the axle somewhere, there is no way the amount of caster change that is available in the eccentrics will have any effect on vibes UNLESS a component is bad. Predominantly on the front end if you have not changed the unit bearings I would be pulling brakes and spending time check them for issues.
