8.4AN has a mind of its own!
First road trip
Exhaust smell in cab
I have a new 2014 2500 Laramie Crew Cab 4X4 Cummins. Got it in June 2014, 2010 miles. The 8.4AN will jump from radio to media and then back numerous times while driving. Seems not to have a pattern just random. Anyone else have this problem? Just wanted to check here before I take it in for service.
Hey check this out! I just subscribed to Chrysler Tech Authority, possibly the hardest site to navigate known to man. BUT:
I now know that you need TSB 08-036-14 REV. A See Below:
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 08-036-14 DATED MARCH 28, 2014, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** INCLUDES MORE RADIO ENHANCEMENTS AND ALL VEHICLES WITH RA3 OR RA4 RADIOS, NOT JUST U.S. VEHICLES.
THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE TRANSMITTAL (RRT) 13-071. ALL APPLICABLE SOLD AND UN-SOLD RRT VIN's HAVE BEEN LOADED. TO VERIFY THAT THIS RRT SERVICE ACTION IS APPLICABLE TO THE VEHICLE, USE VIP OR PERFORM A VIN SEARCH IN TECHCONNECT. ALL REPAIRS ARE REIMBURSABLE WITHIN THE PROVISIONS OF WARRANTY.
SUBJECT:
RA3 RA4 Radio Enhancements
OVERVIEW:
This bulletin involves inspecting and updating the radio software, if required.
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of Chrysler Group LLC.
MODELS:
2013-2014 (DS) 2013-2014 (DX) 2013-2014 (DD) 2013-2014 (DJ) 2013-2014 (DP) 2013-2014 (D2) 2014 (WK) 2014 (WD) 2013-2014 (ZD) 2014 (KL)
Ram 1500 Pickup
Ram Pickup (Mexico)
Ram 3500 Cab Chassis
Ram 2500 Pickup
Ram 4500/5500 Cab Chassis Ram 3500 Pickup
Grand Cherokee
Durango
Viper
Cherokee
NOTE: This bulletin applies to vehicles equipped with one of the following radios.
• Uconnect 8.4A AM/FM/BT/ACCESS (sales code RA3).
• Uconnect 8.4AN AM/FM/BT/ACCESS/NAV (sales code RA4).
SYMPTOM/CONDITION:
08-036-14 REV. A -2-
A customer may experience, one or more of the following conditions.
• **Navigation function may resets itself after using One-Shot Voice Recognition (VR)**.
• **Intermittently the Global Positioning System (GPS) may lose it’s location for a short time and causes routing and positioning concerns**.
• **GPS and Internal cellular device may become inoperative and causes a loss of GPS and cellular functions**.
• **A false Pop-up message may appear “Vehicle Phone Requires Service” even though the vehicle’s phone works properly**.
• **Back-up camera image may be unclear or jittery/stutters at times**.
• Enables Via Mobile software features when released to consumers. (U.S. market
only)
• Able to adjust audio balance / fade settings during a VR session.
• Correct, condition where user could not exit screen off mode.
• Mute button status was not being displayed correctly.
• Presets where not shown correctly or were deleted.
• Enhancements to POI.
• ParkSense tone continuously on.
• Enhancement to navigation routing.
• Radio display may shows “Please insert USB Stick”.
• Enhancement made when video is display in radio when using PAL format video
disks.
• Corrected the temperature slider bar not updating on Manual Temperature Control
vehicles.
• Navigation may not start or may lose position.
• Rear camera may show a black screen for 3 seconds upon going to reverse.
• Enhancements for iPod or iPhone devices that may not start playing after
connecting.
• iPod would not resume playing after a VR session or phone call.
• Radio reset, screen lockup, blank screen or sluggish system response time.
• Compass indicator turns off.
• Touch screen shut down message.
• Radio surround sound will not stay ON.
• Driver memory feature causes Sirius XM failure.
• Loss of radio presets.
• Battery drain - due to radio remains on.
• Uconnect apps don't load.
• AM/FM popping noises and/or static.
• Backup camera display is blank.
• Compass direction may be incorrect.
• Vehicle's Icon changes on the navigation map.
• Loss of vehicle position on NAV map.
• “Vehicle Phone Requires Service” message appears on 8.4” screen.
• Nav turn-by-turn enhancements.
• Nav map guidance enhancements.
• Nav text overlaps in detour menu.
• Nav map, vehicle location enhancements in areas with low GPS signals.
• Navigation shows vehicle in San Antonio, TX.
• Screen only displays startup Logo.
• Screen Half Black Half White after update.
• Radio locked up after attempting to update with a corrupted or incorrect USB flash
drive.
-3- 08-036-14 REV. A
• Phone/Navigation Overlay Screen Freeze (WK only).
• Heated seat controls through radio do not function/display correctly during startup.
• Speed controlled volume not functioning correctly.
• Steering Wheel Control operation corrected at startup.
• Tuner mutes on startup.
• HD now defaults to 'OFF' for reduced complaints about 'channel switching' .
• “LO” temps displayed upon each vehicle start.
• HMI Lock up in SXM mode after ignition cycle.
• Voice Recognition (VR) enhancements.
• Point of interest screen locks up.
• Error message when plugging in iPod.
• Balance/fade setting changes after ignition cycle.
• Clock enhancements.
• Phone book enhancements.
• Rear climate control display frozen.
• Translation enhancements.
• Erratic pop ups in HMI.
• Added Teleprompter.
• Blue tooth, phone, iPod, auto streaming, connecting/disconnecting enhancements.
• Phone quality and pairing enhancements.
• Audio control locked after using VR feature.
• Travel link enhancements.
Get the update but most likely the Media Hub in the center console. Many have had to be replaced for a poor connection.
Sag, Hoping I can explain what I keep seeing on my truck and you could point me in the correct direction.
Initially,my Laramie with 8.4AN had provisions for presetting the cooled seats for startup. During all the trips to the dealership for the vibration issues, the techs pulled the VIN and did two pages of software updates...
Since then, the screen for setting the cooled seats has disappeared. The presets for heat are still there, but the cooling is gone.
When I start the truck, sometimes they startup on HI cooling, but most of the time they start up on LOW.
In your opinion, could this have to do with the above mentioned update? Or does this have more to do with the Media Hub? I also have a RECALL for the RF hub needing to be flashed, AND the drivers door keyless entry button is having issues... are they all related or is it more likely that its 3 seperate issues?
I had the identical issue with my truck, it was driving me nuts. Dealer looked at it, found nothing. I noticed when it would do this that it always switched back and forth between Aux and whatever other source I was using. Up to this point I hadn't ever plugged anything in to the Aux input. One day I was curious if it would still do this if I had something connected to the Aux input, so I plugged in my earbuds, just as dead input obviously. The problem went away. After about a week of not having the issue occur ( it used to happen every time I drove the truck) I unplugged the earbuds. It's been a couple of weeks now without the issue occurring. I believe there was an issue with the plug , where due to the vibration of driving something was making contact and making the radio think something was being plugged in to the Aux input. Inserting the 1/8" jack in the input seems to have moved things so that they no longer make connection creating the false input. Try it, it's free. If it doesn't work go back to the dealer.
Thank you for the help, you are absolutely correct. It worked for me.
I did plug in a patch cable with out connecting anything on the other end and that made the problem go away until I got it in for service.
I did take it in Friday and they found the USB/AUX/SD module in console was bad. The 1/8" jack is shorted out. New one on order. They will call as soon as it is in. Until then I will use your idea and keep ear buds plugged in. Thanks for all the input from everybody!
There is always a reason... My wife recently bought a fiat 500L which has the uconnect system in it. She has the same issues with it as folks on here report with the RAM. I will have her plug something into the AUX jack and see if it works on her fiat. Whatever sub contractor they have making their media hub didn't do their job very well!
Media hub replaced and the truck is now problem free!!!
3 fill ups in a row that averaged 19.2 MPG empty going to work 26 miles each way mostly on the highway at 70MPH.
9 to 12 MPG while towing our pontoon boat at 70 MPH.
We are very happy with this truck.
Good to know, I have a few of those symptoms, all intermittent. Black screen in reverse, radio/media/radio/media/radio......and phone has been "downloading" for a week.
