Did you try ether yet? If not, do as mentioned above and remove heater grid wires, remove intake boot at the intake horn, and shoot just a LITTLE ether in as someone is cranking. If it won't try to start this way then we are looking at broken camshaft, broken crankshaft, broken timing gear, missing teeth on timing gears, etc.
BTW, when you crack the injector line loose at the injector is there 1. no fuel, 2. fuel dribbling, or 3. fuel squirting out? BE CAREFUL!!! FUEL UNDER PRESSURE CAN PENETRATE SKIN AND CAUSE INJURY OR DEATH!!! I know a guy who lost his arm up past the elbow from hydraulic fluid squirting out of a broken hose. Fluid went into his arm, he woke up in the hospital with his arm amputated in order to save his life. And hydraulic systems typically generate 3000 psi or less. Our fuel injection systems can approach 18,000 psi, and over 25,000 psi in the HPCR systems.
Trent
On second thought, is there fuel going into the pump? Need as much detail as you can give in order to know which way to direct you.
Trent
