Congrats - those are some good numbers. I must say though, that the graph looks kinda fishy. How did the motor drop 1200ft-lbs of torque in 10mph (from 129mph to 139mph) and the HP only went down maybe 50hp?
Do you have that graph vs RPM?
Let me quantify: Look at the peak values given on the cursor line. 1718. 46tq / 913. 66hp. We can use the HP/TQ formula (generally accepted as HP=(TQ*RPM)/5252) to work backwords. Here, (HP*5252)/TQ = RPM
At that point in the graph (913. 66 * 5252) / 1718. 46 = 2792 rpm. Seems feasible for 118mph.
Now look at 132mph, where the two graphs intersect. Looks to be about 850hp/tq to me. So lets run this through the same calculation: (850 * 5252) / 850 = 5252rpm. So in 14mph, we had an increase of 2460 rpm?
To go to the last point on the graph, lets look at 150mph. Here, the TQ is down to about 200ft-lbs (maybe a little less), and the HP is still up around 680hp. Now, (680 * 5252) / 200 = 17856rpm... that's one high revving cummins!
Just doesn't add up. Not trying to take anything away, but the graph doesn't make sense.
