I have a problem on my conversion. Here is a link to it.
https://www.turbodieselregister.com...ersions/189421-deatails-promised-finally.html
I bought motor mounts from fordcummins.com about a year and a half ago. (I know, I am slow. ) Here is the problem, I set the engine in the truck using the mounts, and it appears to be too far forward. There is approximately 2. 5 inches between the firewall, and the rear valve cover. Where the engine sits now, there is no way the mechanical fan will clear the radiator, which is the factory 4 core diesel radiator from the Ford. You can see the mount bolted to the side of the block in one of the pictures I posted. I called fordcummins.com, and asked them if something was wrong with the set up. Their recommendation was to re-drill the holes to move it back. WRONG. There is not enough room to move it back on the mount or the frame. The other suggestion was to buy the "New and Improved mount", with a previous customer discount. Appreciated, but not enough if I wasted $260 on these mounts.
What I was wondering, would anyone happen to have pictures from their conversion showing the clearance between the the firewall, and the fan and radiator. Also some pictures of how your mounts set would be appreciated. I am wanting to make sure I haven't got something screwed up before I discuss this with them a little more intensely. Thanks, Nicholas
