Well, smoking like what? I can only imagine what your smoke looks like. I don't know where you are located so don't have a clue as to how cold your are at your location. Is your manifold heater functioning as it should. There are after all some several things that you should check out before you get to thinking that your baby has died on you.
But, from many years of servicing diesel equipment from all the manufacturers, my first impression from your description is that you have a sticking injector/s. You can tell for sure if it is only one cylinder by LIGHTLY touching the manifold at the head port of each cylinder to determine if each cylinder is fireing. With the turbo, it harder to tell after just a little running as everything warms more evenly than if you have unobstructed exhaust. You could certainly have more than one cylinder that isn't fireing up. I have on occasion removed the ehaust manifold to know for sure. I am guessing that you do not have considerable experience servicing these engines as what you are describing is common enough,-- and certainly fixable.
PM with your email address if you want to go into greater detail.
James
