Details here: TDR Privileges
It pops and binds when turning. Ive changed the gear oil twice now. I even used friction modifer, but no changes. lt is a single wheel one ton with 3. 54. 1 gears and a 5spd.
Check your tire pressures on the rear axle. They should be the same, if you have the Dana Trac Loc. Different tire diameters wear the clutch pacs quickly. However, it sounds like your clutches need to be replaced. You can get the kit from Randys Ring and Pinion. GregH
