HTML:
that you can't "hop up" the VE pump enough
Ummmm, how much is enough? I have some bent and broken pieces that had "enough".
You kinda gotta sneak up on it and work at it a little but the i think it has been established the VE pump is capable of delivering enough power to be usable. Obviously the later models will make more but the gen 1 engine is far from anemic.
I priced a trans at about $4500 with billet input/hub and a hefty TQ converter. The controller, adapter, plate, and starter can be had for about a grand. If you add a billet output and the rest of the little things it will push you a little over $6k and it all should bolt in with little problem. Me thinks somebody wants to make a bunch on the job cuz I can't see the labor and minor fab work being worth that much. Maybe its just my perspective.
My . 02.
