'93 Dodge/Allison conversion questions...
Just letting you guys know.
Water pump rotation direction.
HTML:
that you can't "hop up" the VE pump enough
Ummmm, how much is enough? I have some bent and broken pieces that had "enough".
You kinda gotta sneak up on it and work at it a little but the i think it has been established the VE pump is capable of delivering enough power to be usable. Obviously the later models will make more but the gen 1 engine is far from anemic.
I priced a trans at about $4500 with billet input/hub and a hefty TQ converter. The controller, adapter, plate, and starter can be had for about a grand. If you add a billet output and the rest of the little things it will push you a little over $6k and it all should bolt in with little problem. Me thinks somebody wants to make a bunch on the job cuz I can't see the labor and minor fab work being worth that much. Maybe its just my perspective.
My . 02.
One thing no one has mentioned yet. You talked about regearing the rears. On the 3:07 axles you have. You will not do this. The 3:07 axles are 3:07 only. The cases and carrier assy's are one off. To change gearing you need axles that were made for 3:54's and up. Finding those geared axles isn't to hard. Plus there are 1st gen people here wanting 3:07's. So finding someone to trade you a set of higher 3: series gears shouldn't be a problem.
On your question of the 2nd gen. Your hauling a load that would be a class 5 weight size tractor. Your hauling it with a class 3 truck. I would sell the class 3 and buy the class 5 it will run longer with less drivetrain problems and a bigger enigne to.
Well, after much deliberation and weighing the advice of 30 or so TDR'ers and conversion/hop-up specialists, I decided to try to find a '97 or '98 truck that would suit my needs. I figured that I could even get one and replace the transmission and still be money ahead. That is, until I started looking at what was available. A few fairly good deals in TX and CA, but nothing anywhere near VA that seemed reasonably priced and in reasonably decent shape. So, while I was visiting my local Dodge dealer to ask him to put my name on a list to call me if he ran across one, he talked me into buying a 2005 3500 Quad Cab SRW 6-speed (because Chrysler won't warranty an auto with an exhaust brake on it, and I refuse to be without one). So there will soon be some questions in the 3rd Gen forum from me, and a classified for a '93 Dodge for sale...
Thanks to all for the help - it was very much appreciated. I really wanted to go with repairing the '93, but since it's a work truck and not a play project, the reality of time (or rather downtime), reliability and availability of places to work on it finally overcame what I wanted to do and told me what I had to do. (A dealer invoice price and $3k worth of incentives didn't hurt, either... )
Mark
Sounds like fun Mark, You can mount nv5600 to a GV to a 205 t case. GV has all the adaptors. I like the idea of the allson. I am thinking of puting nv5600 in a 93. I hall stuff like this too. A guy how halls some dozers and TLBs for me has a 91 with a 6 speed in it has 250 k on it and the trans has never been work on. And only 2 clutches. All he does is hall with this truck. He said he has had loads of 28k on it. I looked in to a allson and gave up on it, to much $. You have to change those gears, no trans is going to like that much waight with no help from the gears. How you keep u joints in it is a trick. MPH X Gear Ratio, divide by Tire Diameter x 336 = RPM at the given MPH in direct drive (1 to 1). 373 with 33" tires would be = to a stock 93 with 235,75R16 and 354 greas. I would think you would want no less then this. Rember more gear creates leverage meaning your trans works less. Good Luck
Dean stock 93 2wd ex cab 195k a litte bit of timeing
Mark
If you're serious about the allison conversion you should check out the post on this site by Gmac, he has done several. I have ridden in three of them and the next transmission that I buy will be the allison for sure!
