Archived 94 12v With Issues (2.39M Video Included)
Archived O1' Pitman Arm Seal At Box?
Archived truck trouble '02 cummins
Calm down, dude. :rolleyes: I'd probaby be frustrated too, but we are trying to help you get this problem nailed in the bud. Pay attention and actually read what is said. Just slow down a little and learn.
It was in the link I posted earlier, for the GSK install, but here it again- http://piersdiesel.com/TechGSK12V.htm
I have BOMBed computer speakers. With the bass turned down and the treble turned up, it is starting to flutter. Not as bad as when you goose it, and it starts to pop though.
Mine isn't as bad when I goose it while reved like yours does, but it does do it some. Need to advance the timing. It will get rid of most, if not all of the white smoke. I get the white/gray smoke, too, under those conditions. Still need to time mine also.
Im not to excited at this min... just browsing ebaums world at the same time ... Mind sort of distracted ... LOL
Timing is in the works ..... going to be advanced 16*
Havent messed with the fuel lines YET.
Thanks for the link I guess I knew that was there but I forgot..... Too MAny Issues and Posibillities and links and people helping
Im printing it out and Will be in a search of some BOMBED GOV SPRINGS
Thanks For your Help
DM
I had a a bone stock 94 and if I pinned the throttle it would rev to about 2500 rpm then start to miss and white smoke really bad. The fix is to install gov spring kit and advance the injection timing to 15* or better. After that it ran really strong (for a 160 pump) to about 3200 rpm. If you are going to bomb it big time then get the 4000 rpm springs kit. Make sure you install 60 lb intake and exhaust springs at the same time.
Best of luck
Malcolm
Seeing how the Bombed Govener Springs are Twice as much ... and this s a budgit bomber ..... and We just want it to run right . . (FOR NOW) then its looking like the
PDR2613000
Governor Spring Kit 3000 RPM
$125. 00 http://piersdiesel.com/DodgeUSPrice.htm
With the guide . . I think we can handle the job. .
is there any other supplyers that may be cheaper?
Thanks
DM
Been Hitting up the WWW
and incase anyone is interested here are the going rates for 3000 RPM Gov. Spring Kits
PDR2613000
$125. 00
Governor Springs
Governor Spring Kit
Increase the governor RPM cut-off with a 3000 RPM Governor Spring Kit.
Price: $125. 00
http://www.tstproducts.com/browseproducts/Governor-Spring-Kit.HTML
GSK3 3000 RPM GOVERNOR SPRING KIT $150. 00
http://www.dieseltrans.com/dodge/price_list.htm
1040187 Dodge 5. 9 12 V Governor Spring kit 3000 rpm $156. 75
http://www.cyclonediesel.com/bdpowerpricelist.htm
Governor Spring Kit(3000rpm) - $105. 00
http://www.smokindiesel.com/dodge/12_valve/12_valve_fueling.html
Governor Spring Kit 3000 RPM PDR2613000 $175. 00
http://jandhperformance.net/Price%20sheet.pdf#search='Governor%20Spring%20Kit'
HUH ???? PIERS SPRINGS THROUGH A SUPPIER LETS ADD $50
1040187 Governor Spring Kit 3000 rpm P7100 Pump Dodge 165. 00
http://store.bd-power.com/ram/product.php?pn=High+RPM+Mechanical+Governor+Kit&tt=ram
2613000
$155. 02
http://www.tadiesel.com/pricedodge.asp
Looks Like SmokinDiesel.com is the Winner So Far
And jandhperformance Gets a Black Eye !!!! ... . BOOOOOOOO!!!!!!
These Are just with Web Searches.
DM
When you buy your parts... . remember the guy(s) who took the time to reply, and the ones who honestly tried to help out. :)
There's a reason many don't anymore..... I'd like to throw my . 02 in, but my speakers are fragged so I can't hear anything. :{
Sounds like it has 1 or 2 dead holes from 1300 and down. Shakes the truck. Top end sounds like a very slight miss, causing a flutter sound. When he gooses it, it backfires.
Agreed. Price isn't everything ;)
Get back to basics
Get your pump back to a known baseline. Install a plate, Install an AFC housing with an aneroid set the timing.
What you probably have is governor spring bounce, like someone posted above, coupled with low timing causing the upper rpm white smoke. All aggravated by big injectors
Install a plate, any plate, install a functioning AFC housing. Set timing to 15-16*. Then start bombing the pump, governor springs, DV's and injectors.
Nothing is worse than trying to diagnose and fix an engine problem when there are so many variables that have been messed with. Unless of course you try to diagnose the problems via the internet from a video.
Read and take some of the advice from the previous posts. There is not one magic screw to turn to fix your issues.
BTW it is not uncommon to have a 1100-1400 rpm bounce with a 160 pump with big injectors, just a fact of life with a 160 pump.
Good Luck. Greg L
BTW ADT at www.smokindiesel.com is a good place to take your truck and to buy your parts
Yeah... Ill most likly get them from SmokinDiesel.
Ls,,, Were in process of Returning the truck to a simalar stock state so we can get it back running smooth.
Thanks
Dm
Just called up Smokindiesel and ordered the 3000RPM springs How ever the price on there Website was a TYPO but he still sold them to me for that . ... ... . Im not sure what his real price is ... . They seem like good people .
Ended up bring $130 OTD with the Rushed Shipping ...
DM
i got another reply
Hi Chad,
You have 2 problems. The first one is governor bounce. It looks like your
gov springs are adjusted too tight, I believe this because the way the tach
rises in your video, it seems to "run away" at about 1400 rpm's to 1700
rpm's all by itself. Do you see this as well? You should be able to move the
rpm's with throttle travel, if you get to a certian point and the engine
seems to rev upward, without you increasing throttle pressure, it means the
gov springs are too tight. This could also cause some of the higher rpm miss
you have, although I suspect that is due to timing. What are you running for
advance on this motor?
Piers
Man these companies are great!!!!
Seems to be another gov spring vote. w/ timing issues on the side
DM
MY Apologies
After Gaining Info from JR Atkins and John form DPS ... . They are 100% sure what the problem is !!!!!
THERE IS NONE !!!
Its just confused !!!
YOU CANNOT RUN 370 marine/375 Horse Injectors on an '94 or an '95
The pump cannot handle it
Reguardless of pop off or flow
The Bottom end Flutter is the pump trying to open the injectors
when RPMS are up the pump has the Butt to push the fuel ... . the cackel at the top end is the motor over running its timing . .
Fixes ... . Either replace Pump with a '96 pump ... or
Return to stock injectors !!!!
for the top end ... . advance timimg to 16* but with the timing advanced about 16* YOU CANNOT RUN WATER METH ... EVER!!
So thats the plan all... .
tomarrow me and partsman are putting stock injectors in ...
friday In goes the 3000 RPM GOV Springs ... DPS said I would need them anyway .
SO one of the first replys on this thread and on my other TDR threads WERE POssible right all along . .
Well See
Thanks Guys
Big props to John from DieselPerformanceShop in Cali for the 1hour conversation.
And to Partsman and his dedication to fixing a sick CTD and contacting JR Atkins
And Always to TDR
Lets just hope its right ..... they seem pretty confident :)
DM
VISIT : http://www.dpsdirect.com/main_dodge.cfm There Dedication to the diesel world is Unbeleavable! ;)
At this time next week ...
I should have a set of good 370 Injectors ... . Would have 2 sets but one set is being traded for some stockers
and An Hx35 - 21CM
If things go as planned .
Maybe EEP will refund our $$$ on the injectors ???? After all they should of known of these issues ..... its not just a little flutter it shakes the tool box in the bed and rattles your eye balls. its Almost undriveable
DM
DieselMinded said:
MY Apologies
There are several members running 370 injectors in a 160 pump with success. A bone stock 160 pump is typically not a good candidate for a set of 370's.
Well we just changed the injectors from 370 marine to stockers ... thanks Tdr members Holysmokes and Partsman for your efforts ...
The Low end flutter has went away... . 2/3 of the way but its still there ... . hoping its gov spring bounce ... as for the top end it still cackels ..... pretty sure thats timing.....
Friday 3000 Rpm gov springs are going in as well as a stock fuel plate and the Secret PDR gov spring adjustment .
This weekend Timing is getting advance to 16*
We will see where were at from there ...
also thanks to John at DPS for his concern,info, and help in getting her back on the road.
DM
Well truck is 100% !!1
YYAAHHHOOOOOO!!!!
Installed 3000 PRM GOV spring (NOT A BAD JOB AT ALL) and it has no flutter smokes like hell and runs like a striped butt ape ... . fuel to 3300 RPM Plus
AWESOME
Thanks for your guys help.
Advanceing the timing toi 16* to get rid of the flutter at the top end .
DM
Thanks DPS,JR,SMokin Diesel, Shieds, TDR , Piers
