Hey guys, I wish to be enlightened on these non diesel trucks. I picked up this truck for a pretty good deal but the trans is acting up. It has a tough time shifting from 2nd to third, when you are on the throttle it will just stay in 2nd, of you lift off, some times 3rd will catch or the engine will just rev freely. Reverse also has a tough time engaging and when it does you can throttle it a little and it will bang into gear. I already did a trans filter change and adjusted the bands according to the fsm for a 46rh. Nothing weird in the fluid, i also used atf +4 instead of dextron 3 mercon. There is also a code for the torque converter clutch solenoid (code 37), but i dont think this would affect the 2-3 shift or reverse. Anyone have any ideas? I'm hoping that its something simple because its not a fancy electronic trans.
Thanks!
Thanks!
