Archived '94 CTD Fan Clutch Going South Fast
Archived turbo problems
Archived Code P0622
Low Fund Warning
I seen the good ones in my TDR search for Around $400 :eek:
Would like to get one alot lower than that like $100 if possible
Couldnt find any in the classifieds
Dont out bid me anyone thats just not right :) but I need to know if this will work on a '94 CTD
http://cgi.ebay.com/ebaymotors/ws/e...tem=7976776909&category=33602&sspagename=WDVW
THIS IS AN EATON PART NUMBER ETN-010010992 VISCOUS COOLING FAN HUB. FOUR BOLT MOUNT WITH SIX BOLT FAN MOUNT. NEW SURPLUS PART NEVER INSTALLED. IT HAS MANY APPLICATIONS. SOME FORD/STERLING CARGO COE USE IT WITH THE CUMMINS 5. 9 ENGINE. ALSO GAS AND DIESEL ENGINES. DIMENSIONS ARE 8" DIAMETER,6" FLANGE TO NOSE, 5" fan blade center opening required
I measured some stuff but Im still not sure if it will work also the stocker seems to have bolts and this one has studs may have to use nuts on the inside ????
I know what it says but I also know about E-bay and this guy has 2 bad feedbacks
I tried to cross referace the part Number But I cant seem to find anywhere to do that.
Thanks a million
If Its the right one I will just BUY IT NOW
I need help fast as the Water pump is probly struggling
DM
DM
You'll want to check your fan blades for any sign of cracks. There have been some reports of failures on 94/95's. In fact, I'm surprised at the listing on Mopar Parts. When I replaced my fan clutch several years ago, there were still some direct replacement clutches in the system, but if you wanted to replace the fan blade, you needed to replace both, because the blade was redesigned and used a different clutch. It might be different now, but that's what I was told then.
Lynn
I bought a lifetime warranty one from NAPA for $139. So far I've only had to replace it once. The last one has lasted longer the the original.
Had to edit the price after I checked my receipt.
