Low Fund Warning
I seen the good ones in my TDR search for Around $400
Would like to get one alot lower than that like $100 if possible
Couldnt find any in the classifieds
Dont out bid me anyone thats just not right
but I need to know if this will work on a '94 CTD
http://cgi.ebay.com/ebaymotors/ws/e...tem=7976776909&category=33602&sspagename=WDVW
THIS IS AN EATON PART NUMBER ETN-010010992 VISCOUS COOLING FAN HUB. FOUR BOLT MOUNT WITH SIX BOLT FAN MOUNT. NEW SURPLUS PART NEVER INSTALLED. IT HAS MANY APPLICATIONS. SOME FORD/STERLING CARGO COE USE IT WITH THE CUMMINS 5. 9 ENGINE. ALSO GAS AND DIESEL ENGINES. DIMENSIONS ARE 8" DIAMETER,6" FLANGE TO NOSE, 5" fan blade center opening required
I measured some stuff but Im still not sure if it will work also the stocker seems to have bolts and this one has studs may have to use nuts on the inside ????
I know what it says but I also know about E-bay and this guy has 2 bad feedbacks
I tried to cross referace the part Number But I cant seem to find anywhere to do that.
Thanks a million
If Its the right one I will just BUY IT NOW
I need help fast as the Water pump is probly struggling
DM
Thanks a million
DM
