I replaced my valve springs in my 1994 Dodge Ram 2500 diesel (automatic trans) and I am having problems getting the pushrods and lifter assembly back in and valve clearances set. There seem to be two places that (at least the intake pushrod) the pushrod wants to seat on the cam or lifter or whatever is down there. The engine is at TDC at #1 (pin in at fuel pump) and I'm on #6. I tried to move the engine clockwise 120 degrees after I did clearances at #1, but I moved it back to TDC at #1 again It's very difficult to tell how vertical they are or centered-you obviously cannot get your head back there. I thought I had it in the right place (seems the intake pushrod is the one that's giving me problems) but when I put the valve assembly back on and torqued it down, there was no play at all to set clearance. One way to seat the pushrod gives me more play, but like I said it didn't have any clearance to set the lash even when the adjustment on the valve assembly was backed off all the way.
Is there a 'cup' down there, or how does the pushrod fit in? Maybe I should remove #5 assembly to see better.
Any help appreciated.
I'm sure #1 valve assembly is OK. Maybe I will take measurements of how high the pushrods stick up at #1 at TDC and then move the engine clockwise 120 degrees and see if I can set the pushrods to get the same height at #6.
