Engine/Transmission (1994 - 1998) 94 TDC Pin
2nd Gen Non-Engine/Transmission Front Rotor Disk Replacement/Turning?
2nd Gen Non-Engine/Transmission where can i get a dana 80 yoke?
I am confused ... ..... I am about to take the IP off my truck and it tells me to push in the TDC pin and turn the motor until the pin engages and the stop turning... ... ... I cant find that pin lol ..... please help.
The pin is located to the rear side of the timing gear housing below the injection pump and above the power steering pump and yes, you have to turn the engine by hand. bg
Ok thanks ... ... I turned the "key" to the 6 o'clock and then continued to turnit until the 1 Cyl was at the top of its travel. I will confirm now that I know were to look for the TDC pin. With the head off its pretty easy to see :)
