First thing is to make sure that all the fuel fittings are tight and not leaking.
Pump the primer bulb, alot.
Try to start the truck. If it doesn't start, stop cranking but leave the key in the on position, and verify that the fuel shutdown solenoid is pulled up all the way.
Crack the first 3 fuel lines that can can easily reach. I think it's 1, 3 and 4.
Try starting the truck, while watching the injector lines for fuel to come out of them. Giving it a little throttle helps. If you are getting fuel to the injectors, it should try to start. When you feel it try to start, or it actually starts, turn the key off, tighten the injector lines and restart while giving it a little throttle.
When it cranks, try to hold it at a 18-2000 rpms until the engine smooths out.
Of course, if you have a little help, you can have the person try to start the truck while you loosen and tighten the injector lines. Makes it a little easier.
Try to avoid cranking for more than 30 seconds though. The starter can get hot if you do.
