Engine/Transmission (1994 - 1998) '95 #6 Plate---How much Power?
Engine/Transmission (1994 - 1998) cruise control, HELP!!!!
2nd Gen Non-Engine/Transmission wet passenger floor board
We've got a 95 with a #6 plate slid all the way forward and 36psi boost, BHAF, 4" exhaust, and star wheel turned towards SMOKE..... Does anyone have the figures on HP and Torque besides what TST's chart shows?
Can not verify it but I was told the amount of boost you make in your one to one gear of your transmission, 4th for a manual and 3rd for a slushbox, before about 1800 RPM or where the motor over boosts due to RPM times 10 is HP.
If you make 36 #'s of boost before 2000RPM's then you are probably in the 360 HP range.
If you spike this much boost figure how much is repeatably consistant and this is probably closer to your HP figure.
Some math for guessing, but still guessing. Good luck
I had my 95 In the Chrysler garage and they said that they jump the horsepower up 50. I think that a bit bull**** that they are feeding me. Will drive the truck on a 100 mile trip today to see the difference. I had the trans service also. Only have 39000 on It so will see If there any difference and will let you know.
My report on power increase on my 95 one ton
Boy what a difference In power got as much power as my 2004 one ton. I was surprise and like It. My 95 pulls the hills real nice and no down shift. I will leave It that way. Have not check fuel mikeage yet?????
