Ive got a 95 ram 2500 that Ive been working on over the past few months trying to pin down a low power / fuel economy problem. I get about 10miles to the gallon so something is going on in there!
I installed a westach fuel pressure gauge and it shows 12psi at idle and anywhere from 12-20psi at 2k rpm depending on what it feels like doing. Iv e confirmed this with a fluid pressure tester. I should be seeing 20ish at idle and more importantly 25+ psi at 2krpm.
I have checked and cleaned the overflow valve. The spring was 1/2" in length. I had the heater screen cleaned and Ive cleaned the screen inside the tank. The only bad thing I can see externally is a little dry rot in the fuel return hose.
How hard is it to swap a lift pump? It doesnt look easy to get at.
Is this what Im looking for here?: http://www.citydiesel.net/supply-pump-dodge-12-valve-p-126.html?cPath=22_26_48
also how bad is it to replace the rubber fuel lines? Looks like there are some special fittings so Id need OEM lines? Or just lop off the crimps and use a clamp over the hose?
