It's not a problem at all, not to mention either way, the VP44 is happy, because over 7 or 8psi at WOT, you still have a huge volume of fuel flowing through at any psi. You can stretch the spring on the return line check valve, or, you can just get a different spring. It's not a problem, just an adjustment. And caveman, why would buying an Airdog have any relevance in this issue? Frankly, the jackassery that the Eckstam's have posted on here made me lose a lot of respect for both sides. It is just plain childish. I would buy a RASP, if anything, if I had to choose again.
