Engine/Transmission (1994 - 1998) 96 5-speed turbo ??s
Engine/Transmission (1994 - 1998) Centerforce clutch holds
2nd Gen Non-Engine/Transmission Dodges deletetion list grows for 2001.
My friend has 96 5-speed CTD 4x4.
There is no apparent mods from looking under the hood, however it has a ton of power and smokes like a train.
I looked too see if there was a tst boost elbow on the turbo and there was no hole drilled for it, like a Hy turbo. The stamp on the turbo said it was a hx 35w. Is that the stock turbo for his truck?
I am guessing whoever did the mods put in a new break off screw and repainted.
more than likely a Dr. Performance kit since his shop is only 11/2 hours away.
Thanks for your help,
Jason
The stock turbo is the HX35W. If there is a boost elbow, it's over on the top of the AFC housing. Trace the line from the wastegate, over across the top of the motor, to the top of the pump. :)
