Engine/Transmission (1994 - 1998) 96 crankcase blow by
Engine/Transmission (1998.5 - 2002) Injector Limit
Engine/Transmission (1998.5 - 2002) Jammers and HX40
My father in law called from his RV out on the road and said that the crankcase breather tube has begun dumping about 2 quarts of oil out every 100 miles. He said that it still has lots of power and sounds like it is running good.
We were wondering if he may have cracked a piston or ring. Not sure what would cause the sudden change in oil blow by.
Thought I would check if any of you have any ideas what to look for.
Appreciate your thoughts.
I have a '95 at about 300HP pulling a trailer for about a half hour at 1200 deg, then an 800 mile trip with tt. -floored for some Branson hills. . Got about 200 miles to a quart then. . It was at about 1200 to the quart up till these trips. At Branson, I noticed a little oil running out the fender and down the door. Got home and oil was getting embarrassing. . A few hundred miles later(empty) and oil just ran off everything underneath. . About 30 miles to the quart. . Noticed dipstick was pushed out so assumed blowby was bad. . Put a 1" plastic tube in oil filler hole, went about 18" and stuck the tube in a gallon jug so I could dump the oil back in. . Never got any oil in jug and the truck stayed clean. . But, oil cunsumption was still less than 100 mi per quart. Drove it about 2000 miles that way (check my old posts, I inquired to TDR also about this) while looking around for a different engine. One day I was headed into strong wind pulling a trailer on a hot day with a dirty radiator. Didn't want to boil radiator over as then I'm stopped. (different engine needed anyway) Temp gauge ran against the red and I watched for the steam in the mirror. Down to 45 MPH so pulled off to the side to get out of traffic and revved engine to about 2 grand. . Cooled down to normal, I took off and did the same thing a few miles down the road. . You got through that drivel, now the punch line--NO MORE OIL USE!! A few days later I gave my tube setup to a fellow CTD with a gobba blowby-my engines as dry as a bone... Incidently, when this was going on, I had a poor starter so it barely turned over. . all 6 seemed to have even compression, the engine ran perfectly, like yours. .
I could be off on the details a little, but it has now racked up another 18k or so almost all pulling a 33' travel trailer with oil consumption at about 1500 MPQt-some drips. . One thing odd, twice I ran empty at 85 MPH and it got about 20 miles to the quart with a huge mess underneath. . 70 MPH with the camper and nary a drop is spilled. . You surely thing I'm nuts or a blowhard--I've got lots of witnesses.
Incidently, when it was really going through the oil, I sampled the oil. The only noteable outawhack number was chrome, they suggested I had excesseve ring wear. .
Only thing I can figure out is that I scored the walls evenly, then running it hot at a little less throttle than when I messed it up somehow reseated (or daresay broke in) the rings again. .
I can give you more detailed info on my accidental fix--hey, a piece of cardboard and a half hour-what you got to lose?? You don't HAFTA tell anyone!!
I just posted previously and for got to add that I thought I cracked a piston or a ring also, but when it slowly cranked over (evenly) it made my wonder as I figured when it hit the bad cylinder that would waste that much oil it should lurch right there. . Maybe a quick check could be to run the battery down until it turns over slow-see if it is even on all 6. . good luck
These trucks seem to like oil. Mine goes through quite a bit of it if I'm going over 80 mph for extended trips. Still runs strong and get good mileage, just likes it's oil. You can only worry so much, then just keep it topped off.
although 20 miles per quart is definately rediculous. :--)
point of my post- :confused:
whats the engine temp at time of most consumption??
Is he sure it's not a leaky turbo oil line or one of the other 20 gaskets that love to **** oil everywhere at high RPM?
sometimes it's hard to tell when its covering everything
