Anybody have any recommendations for repairing small, let's say a little larger than pinhole leaks in my oil pan? Road salt/corrosion took its toll after 11 years. A couple came through the steel on the downside section behind the crossmember and now she's developed a drip :{ . What do you think? Drain the oil, scrape then sand the sufrace, then use : fiberglass ? carbona ? Any ideas you guys may have would be appreciated. Replacing the pan is definitely a job I do not want to tackle, which I'm sure you all would understand. Thanks in advance. Mike
