Hey guys;
Here's a question for you. I may have the oppertunity to pick up a p-7100 pump off of a 96 engine. If I get the pump and all of the front end parts off of the 96, is there any other parts I will need to install this pump on my 93? Furthermore, if I do get the p7100 in the truck is the best injector still going to be the lucus or will the 370 diamond b injectors fit the 93 but have not been used because of pump limitations.
Then there is the question of the hx-35 turbo and 12cm housing verses stock 93 turbo with 16 cm housing?
Any info and feed-back will be appreciated.
Jim
Jim
