Tried to diagnose this by searching w/o any luck. Only found brief mentions of TPS, sensor and solenoid problems as possible culprits.
A year or more ago my transmission began to develop a funny 1-2 shift. It normally happens shortly after startup when the air and the engine are cold and is more frequent when the 1-2 shift occurrs in a left-hand turn. The engine revs without power to the driveline for a second and then it "catches" and resumes normal operation. The problem has gotten progressively worse and the transmission has begun to exhibit a hitch when accelerating after a few minutes of idling in drive such as at a stoplight. Again, no power to the driveline and then an little bump followed by normal operation. This problem happens erratically, no matter the temp of the air and engine. Now, the transmission will work normally, at idle in drive (like you're easing through a parking lot looking for an empty space) when it suddenly acts just like you've placed the gear selector in neutral for a few seconds. It exhibits the same behavior in reverse. As with the other problems, after a few seconds, the transmission resumes normal operation. The fluid level is right on the mark (warm engine running in neutral) and the transmission pulls as strong as it ever did under heavy throttle or at cruise speeds.
I have a BD TC and Transgo TFOD-HD2 shift kit that have been installed for the last 130,000 miles.
A friend with a '98 CTD and another with a '98 gasser have similar problems with stock transmissions.
Any ideas?
Any ideas?
