from the '97 Service Manual, Pg. 8V-3: an "OC" (open circuit) will appear in the display in place of the temperature, when the sensor is exposed to temperatures below -40 deg. C (-40 deg. F), or if the sensor circuit is open.
There is a sensor test & a sensor circuit test described.
Sensor test: (1) Turn the ignition to the off position. Unplug the temperature sensor wire harness connector.
(2) Measure the resistance of the temperature sensor. At -40C (-40F) the sensor resistance is 336 kilohms. At 55C (140 F) the sensor resistance is 2. 488 kilohms. The sensor resistance should read between these two values. If OK, go to the Sensor Circuit Test. If not , replace the faulty sensor.
Sensor circuit test: (1) turn the ignition switch to the off position. Unplug the temp. sensor wire harness connector.
(2) Connect a jumper wire between the 2 terminals in the body half of the sensor wire harness connector.
(3) Remove the overhead console. Unplug the overhead console wire harness connector.
(4) Check for continuity between the sensor ground circuit & the ambient temp. sensor signal circuit cavities of the overhead console wire harness connector. There should be continuity. If OK, go to step 5. If not OK, repair the open circuit as required.
(5) remove the jumper wire from the temp. sensor wire harness connnector. Check for continuity between the sensor ground circuit cavity of the overhead console wire harness connector and a good ground. there should be no continuity. If OK, go to step 6. If not OK, repair the short circuit as required.
(6) Check for continuity between the ambient temp. sensor signal circuit cavity of the overhead console wire harness connector & a good ground. There should be no continuity. If OK, see the compass & display module diagnosis in this group. If not OK, repair the short circiut as required.
The diagnosis testing shows either a faulty sensor, faulty sensor wiring, or a faulty display module, which has to be replaced. Hope this helps. John
