My head is hurting from thinking about this and I did a lot of searching yesterday. Google kept popping up other Dodge Cummins forums. Other guys had similar problems, but the ESS change didn't always fix it.
My light switch quit on me and was changed on Jan 16, 12 and the headlights work fine. I think I found my fusiable link and it's not blue, but red. It's the heavy gauge wire going from the drivers side pos term to the power dist center right? I don't remember and didn't write it down, but maybe it was changed back in Dec 07 when my intake heater relay was fried.
I removed the nut where the fusiable links attaches to the power dist center and cleaned and coated it with dielectric grease. Before I bolted it back together, I put my multi-meter on 2k ohms and checked the resistence of the fusiable link, it was . 021.
I turned the key on in the ignition and tilted the steering wheel up and down many times with no change.
What you guys are saying is that I probably have two problems, instead of one. It's 24 degrees outside and I thought I would try to start it and see what happens and of course without the wait to start I don't have my intake heater grid. When I do bring it to my mechanic I'll probably have to tow it the 5 1/2 miles, which is no problem, because we live in the boonies. I don't know anybody with a 97 auto, but my buddy has a 96 with an auto.
I looked at Larry B's heavy duty shutoff solenoid kit which includes a relay and a fusible link for $139. Should I buy this for my solenoid problem? For the ESS somebody online said to order it from Cummins, it would be cheaper than the dealer. When I lived in the Detroit area we had two Cummins stores and I used to buy parts there, but that's 600 miles away. I can't seem to find an online Cummins store.
I called my Dodge dealer for a price check on an engine speed sensor and the parts guy didn't know what it was. We got off the phone and he said he would look in the FSM and see if he could find what it is.
Ed
Ed
