When testing the Ignition Off Draw as at page 8A-10, the manual states that after 3 minutes this should reduce to max 25 ma. However, page 8M-14 states that the seatbelt ratractor latches only de-energise after 30 minutes. On my truck, this gave a 400 ma draw for 30 minutes. This is important if you're trying to trace the cause of flat batteries, as I was. Nick
This came to light when I attempted to trace the source of an Ignition-Off Draw (IOD) of 400 ma instead of the maximum of 25 ma after waiting 3 minutes, as stated in the manual at pages 8A-10 and 11. This was in connection with a flat battery problem, which eventually turned out to be a defective battery. I found the IOD reduced to zero when the IOD fuse (12) was removed, so I went to page 8w-12-12, and attempted to isaolate one by one the 14 items supplied by this IOD fuse. Eventually, by disconnecting the loom under the driver's seat, I found the drain to be from the Seatbelt Control Module. I then went to page 8M-13, to read and understand the Seatbelt Control Timer Module (SCTM). I read at page 8M-14 that the retractor latch solenoids are only de-energised after 30 minutes!! I repeated the IOD test, with the doors closed, and waited 30 minutes, at which time the IOD reduced to zero! The truck is perfect, but the IOD test page says 3 minutes. I wasted a morning on this. If we had a thread or forum called "98 Service Manual Notes" or similar, any person buying a manual could run through all the posts, make notes on the pages of things of interest, and perhaps save a lot of aggravation and time. There is a huge amount of knowledge amongst you all, and sharing it in this way might prevent newbies like me repeating errors that have already been detected by others.
