I've been putting this off for years, but it is now annoying me enough to make it right.
My signature shows what is in the transmission.
Full stop, hard right sweeping turn in a six lane intersection results in good normal solid up-shifts without any skipping or gear hunting.
Using a normal 1/3rd throttle, 1500-1800ish RPM take off and just hold the throttle steady.
Same pedal action, but make a left hand turn in any large intersection results in the transmission skipping between shifts. It is either loosing oil pressure, or it is hunting back and forth for up-shift points.
Fluid level is exactly on the top of the hash marks, about 3/8ths inch below the double S curves in the stick.
My method of stopping this aggravation is to turn OD off, put transmission in 2nd gear. It makes the 1-2 shift before I can move 15 feet, then it just stays in 2nd gear until I manually up-shift it.
I've been shifting it that way for more years than I can remember. I would like to fix it once and for all.
Any of you automatic transmission gurus know what is wrong?
John
John
