sstockton said:yeah 5th gear nut will want to be fixed but there shouldn't be any problems with it at this stage in the game. 75k isn't that many miles, and it's not a terribly expensive fix. Also check to see if it is a 53block. The 53 blocks have been known to crack, not all of them do but some, so that is something you may want to take into consideration. If you can, take a fuel pressure gauge with you and hook it up to the schrader valve on the IP, see what your fuel pressure is. If it is low, below 6psi or so, damage to the injection pump may have occured. Other than that, just look at the usual things you would look at when buying a used vehicle. Nothing else really comes to mind.
Sean
Supermod56 said:There is a good chance that it is a 53 block, look under the injection pump above the pan rail, you should see a number 1" high, if it is a 53, walk away!! If it's not, buy it and toss the Banks kitOn the 5th gear nut issue, as long as you don't plan on towing a lotta weight right off the bat, you should be good.
Tom
Cummins724 said:I haven't had any problem with the 5th gear nut, but I've heard of it being a common problem.
