when you installed the new calipers did you clean the grooves that the caliper slides in? if not the caliper could be sticking . remove the calipers , file down any rough spots, then use emery cloth or sand paper on the grooves. apply silacone high temp grease to slides. unless your calipers are seized this should help.
