I know this has been covered and i tried searching but no luck, I have a comp box off a 99 5 speed will it work with either an 01. 5 ho 6 speed or an 02 so 5 speed? I know the map sensor plugs are different but i was also told there was an adapter to make it work? I've been told if i run a constant 5volts to the map sensor on the comp box it will work?
Thanks guys
Preston
Thanks guys
Preston
