I have a 1999 240k miles) stock diesel 4x4. I drove it in a blizzard to work (shut off for 8. 5 hrs around 10 degrees F) and Drove home 33 miles. Shut it off. (worm garage) It ran like a dream. Two day later I went out to start the truck and it spins over but will not try to start no smoke or anything. (like the old 12v with the fuel shutoff pulled) My fuel pump run (holey fuel pump) I have fuel pressure at the filter with the key on it sprays out the drain when i open it. tried to read the code under the dash got none. (used a cheap one from the neighbors. should the standard scanner work or do i have to buy another one. (I do have a spair ecm)
