I have a stock 99 2500 LB Quad Cab. The truck has been pulling to the left when the brake is applied for the last 15K miles. The truck has 83K miles on it. The truck is turning into a democrat, while it's owner has other views. Help my truck change it's ways... . !
When you look at the left front brake pads, the left front will last about 15K miles, the right are in great shape. Clearly the left front caliper is dragging. Stopping on a dirt road, the left front locks up way before the others do and with light brake pressure. I have replaced the rotors, twice, due to thermally induced cracks and blue discoloration. I have replaced the wheel bearing, and the caliper with a rebuilt one and am now running with vented and slotted rotors from NAPA. These rotors have not warped yet and provide a much improved braking capacity but still the problem persists. I have greased the caliper pins with silicone grease, made sure the rear drums are adjusted correctly. Any Ideas? I am close to needing to replace the front pads again, but want to fix this problem for good.
Democrats are welcome to reply!
