Code P1693 --- PCM ? Would like to know what the most complaints are for --with this code.
Next time it doesn't want to start. Open the hood and disconnect the temp sensor by the thermostat and try to start. If it starts right away the problem is probably in the VP pump. I had this happen on 3 24 valves and the only cure has been to change the pump. I think it is in the electronics. By the way it will throw a code when you try this but it will go away after a couple of starts after you plug the sensor back in.
Nigel
