a/c blows
Excessive Wear on Outside Edge of Front Wheels
Brite Box with Fog Light Control
my fan still blows when the key is turned off . i have to turn the fan switch off every time i get out of the truck. the key can be out of the ignition and you can turn the fan on or off. any ideas ? thanks 2003 3500
That's a new one on me. Does the door chime "ding" when the door is open and the keys are out?
I'm wondering if it's a problem with the ignition switch. Does the radio continue to work with the key off?
Ryan
No Chime With Key Out Of Ignition Nor Does The Radio Keep Playing. it Seems To Be Just The A/c Fan. thanks For The Reply
Mine does the same... just the blower motor runs. Will try to replace the electrical portion of ignition switch. BWD Part #CS829 at Advance Auto.
I just had the same problem-in addition to blend door and mode switch issues. The ignition switch tested bad, was replaced. Problem seems to be solved, but will watch closely for awhile!
Dennis
