Details here: TDR Privileges
my fan still blows when the key is turned off . i have to turn the fan switch off every time i get out of the truck. the key can be out of the ignition and you can turn the fan on or off. any ideas ? thanks 2003 3500
I just had the same problem-in addition to blend door and mode switch issues. The ignition switch tested bad, was replaced. Problem seems to be solved, but will watch closely for awhile!
