OK, so a little while ago my A/C system had a bit of a moment. It was a really hot day on really hot asphalt and while idling the truck with the A/C on the system reached too high of a pressure and the over pressure relief valve opened. It vented some freon and also left a small green puddle of compressor oil, about a foot in diameter, on the ground. I have recharged the system but am wondering how to determine if I should add oil. I guess I know I should add some as some was dumped out but how do I determine just how much? Is it critical, or should I just dump some in and move on? This is a relatively new compressor and I really don't want to be replacing it.
And for those that would ask, why did it over pressure in the first place?...
The compressor was replaced a few weeks before this happened and I expect the tech put in a little too much freon. It was working but not as well as it should have. I was planning on checking the pressures when I returned from this trip I was on. Where I was idling, in Bakersfield, CA. , it was quite hot. Upper 90s to low 100s, and in the sun, on the hot asphalt it was probably well over 120. I think that at idle with the lower fan speed, the extreme heat, and the possible over filled system. that the condenser just couldn't shed enough heat to keep the system pressures in check. The fan is kicking on as it should and with the gauge hooked up it looks like things are working fine. I'll keep an eye on things but so far I think its all ok.
